We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter converter is an ideal solution for converting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a VGA input. This adapter converter carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description | C2G 20cm DisplayPort to VGA Adapter Converter - DP Male to VGA Female - Black - VGA adapter - 20 cm | Type | VGA adapter | Features | Latched | Length | 20 cm | Connector | DisplayPort - male | Connector (Second End) | HD-15 (VGA) - female | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Length | 20 cm |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
