We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This HDMI to DVI-D Digital Video Cable provides a reliable connection between devices with an HDMI output to a DVI-D display for desktop and home theatre applications requiring high levels of picture quality up to 1080p resolution. Similarly, this bi-directional adapter cable allows you to connect a DVI-D source device to an HDMI display. This cable is tested to perform at industry standards and is backed by a lifetime warranty.
Product Description | C2G 2m HDMI to DVI Adapter Cable - DVI-D Digital Video Cable - adapter cable - HDMI / DVI - 2 m | Cable | Adapter cable - HDMI / DVI | Technology | Double shielded | American Wire Gauge (AWG) | 30 | TMDS Links | Single link | Length | 2 m | Colour | Black | Connector | DVI-D - male | Connector (Second End) | HDMI - male | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Adapter cable |
Interface Supported | HDMI / DVI |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 2 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 18+1 pin digital DVI (Single-Link) - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
