We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
Product Description | C2G 2m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 2 m | Type | DisplayPort cable | Length | 2 m | Connector | Mini DisplayPort - male | Connector (Second End) | Mini DisplayPort - male | Colour | White | Manufacturer Warranty | Limited lifetime warranty |
General | |
Length | 2 m |
Colour | White |
Connectivity | |
Miscellaneous | |
Compliant Standards | DisplayPort 1.2 |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
