Gain maximum flexibility in positioning your monitor with this angled connector cable. The right-angled connector allows installation in even the tightest locations; the cable breaks down from this connector. This premium VGA extension cable is ideal for video presentation devices, video splitters, and KVM switches. Constructed from premium grade video cable, it uses a combination of coax and twisted pair to accommodate cable runs up to 30 meters away without a booster (in most cases), and without the typical distortion problems associated with extended length cabling runs.
Product Description | C2G Premium SXGA 90° Down Angled - VGA cable - 3 m | Type | VGA cable | Technology | Shielded twisted pair coaxial | Features | 90° connector | Length | 3 m | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - male | Compliant Standards | RoHS |
General | |
Type | VGA cable |
Length | 3 m |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - male |
Miscellaneous | |
