Go the distance without ghosting and signal distortion. Constructed from premium grade composite coaxial and twisted pair shielded cables, this ultra-premium monitor cable ensures crisp, distortion-free video so you have maximum monitor positioning flexibility. Uses three internal coax lines for red, green and blue. Ferrited to protect against EMI/RFI interference, this double-shielded cable consists of 125% foil shielding and 90% tinned copper braid shielding.
Product Description | C2G Pro Series UXGA - VGA extension cable - 5 m | Type | VGA extension cable | Technology | Double shielded coaxial | Length | 5 m | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - female | Compliant Standards | RoHS |
General | |
Shielding Material | Foil with tinned copper braid |
Length | 5 m |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
