RapidRun Optical is designed to be the standard for in-wall HDMI audio/video installations. Using pre-terminated break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations. Ideal for high resolution displays utilising HDMI, this flying lead allows for an extremely clean finish with little to no cable clutter at the source.
Product Description | C2G RapidRun Optical HDMI Receiver Flying Lead - digital audio adapter - 10.1 cm | Cable | Digital audio adapter | Length | 10.1 cm | Colour | Black | Connectors | RapidRun optical - female | Connectors (Second End) | HDMI - male , Micro-USB Type B (power only) - female | Features | Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), Ethernet Return Channel, HDCP compliant | Manufacturer Warranty | 3-year warranty |
General | |
Cable Type | Digital audio adapter |
Length | 10.1 cm |
Colour | Black |
Connectivity | |
Connectors (Second End) | 19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female |
Miscellaneous | |
Compliant Standards | CSA, UL, FCC, EMI, RoHS Phase 2 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
