The i-SENSYS LBP210 series are fast, double sided, A4 black and white printers engineered to enhance work flow and productivity, and cut costs. Delivering improved, high-quality results, they are ideal for SMEs.
Product Description | Canon i-SENSYS LBP215x - printer - B/W - laser | Printer Type | Workgroup printer - laser - B/W | Weight | 9.9 kg | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76.2 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 63.1 ppm - B/W - A5 (148 x 210 mm) , Up to 30.3 ipm - B/W duplex - A4 (210 x 297 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n) | AirPrint Enabled | Yes | RAM Installed (Max) | 1 GB | Language Simulation | PCL 5E, PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG | Media Type | Envelopes, labels, plain paper, recycled paper, thin paper, postcards | Total Media Capacity | 350 sheets | Media Handling | 100-sheet multipurpose tray, 250-sheet paper cassette | Monthly Duty Cycle (max) | 80000 pages | Recommended Monthly Volume | 750 - 4000 pages | Networking | Print server | Printer Features | Mopria certified | Power | AC 230V | System Requirements | Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Apple OS X 10.8.5 Mountain Lion or later, Microsoft Windows Server 2016 | Dimensions (WxDxH) | 43.8 cm x 37.3 cm x 31.2 cm | Manufacturer Warranty | 2 years |
General | |
Printer Type | Workgroup printer - laser - monochrome |
Printer | |
Built-in Devices | 5 inch LCD touch screen |
Connectivity Technology | Wireless |
First Print Out Time B/W | 5.5 sec |
Fonts Included | 93 x PCL , 136 x PostScript |
RAM | |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm) |
Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Media Weight | 52 g/m² - 163 g/m² |
Media Feeders | Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 163 g/m² |
Output Trays Capacity | 150 sheets |
Duty Cycle | |
Networking | |
Security Protocols & Features | Secure Print |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 1600 pages |
Features | Google Cloud Print |
Power | |
Power Device | Power supply |
Voltage Required | AC 230V |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 1300 Watt |
Power Consumption Stand by | 10 Watt |
Power Consumption Sleep | 0.9 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, uniFLOW online, uniFLOW online Express, Canon Universal Login Manager |
OS Required | Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Apple OS X 10.8.5 Mountain Lion or later, Microsoft Windows Server 2016 |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
Sound Emission (Operating) | 56 dB |
Dimensions & Weight | |
Width | 43.8 cm |
Depth | 37.3 cm |
Height | 31.2 cm |
Weight | 9.9 kg |
Service and Support | |
