We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
All-in-one color inkjet for home offices. The Canon MAXIFY MB2750 Series provides mobile printing and cloud integration, while its 500-sheet paper capacity and fast 24 ipm mono print speed maximize productivity.
Product Description | Canon MAXIFY MB2750 - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Ink-jet (colour) | Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink | Monthly Duty Cycle (max) | 15000 pages | Recommended Monthly Volume | 200 - 1000 pages | Max Copying Speed | Up to 22 ppm (mono) / up to 11.5 ppm (colour) | Max Printing Speed | Up to 24 ipm (mono) / up to 15.5 ipm (colour) | Max Printing Resolution | Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 300 x 300 dpi, 200 x 200 dpi | Scanning | 1200 x 1200 dpi | Display | 3" | Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 50 sheets | Media Size | 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper | Standard Media Capacity | 500 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, MAXIFY Cloud Link, Mobile Printing, access point mode | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 46.3 cm x 38.9 cm x 32 cm | Weight | 12.1 kg | Manufacturer Warranty | 2-year warranty |
General | |
Fax Type | Plain paper |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 3" |
Display Features | Touch screen |
Memory | |
Supported Flash Memory | USB flash drive |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Copying Features | 2 on 1, 4 on 1, Frame Erase Copy, collation copy |
Printing | |
Inkjet Technology | Canon FINE (Full-lithography inkjet Nozzle Engineering) |
Ink Cartridge Configuration | 4 individual ink tanks |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Ink Type | Dual Resistant High Density (DRHD) |
Automatic Duplexing | Yes |
First Print Out Time B/W | 6 sec |
First Print Out Time Colour | 7 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Colour Depth (Internal) | 48-bit |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 250 pages |
Fax Machine Features | |
Speed Dialing | 100 station(s) |
Document & Media Handling | |
Max Original Size | A4 (210 x 297 mm), Legal (216 x 356 mm) |
Min Media Size | 89 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 275 g/m² |
Supported Media Type | Envelopes, plain paper, photo paper, glossy paper, matte paper, high resolution paper, luster paper, semi-gloss paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm, 200 x 250 mm |
Supported Envelope Sizes | International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm) |
Document & Media Handling Details | 2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) |
Speed Details | Printing: up to 24 ipm (A4) - B/W , Printing: up to 15.5 ipm (A4) - colour , Copying: up to 22 ipm - B/W , Copying: up to 11.5 ipm - colour , Scanning: up to 18.5 ipm - B/W , Scanning: up to 15.5 ipm - colour |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 |
Security Protocols & Features | WEP, WPA-PSK, WPA2-PSK |
Operating System Support | MS Windows 7, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, MS Windows 7 SP1, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Windows 10 Mobile, Apple Mac OS X 10.8.5 or later |
Software Included | Drivers & Utilities, Canon Easy-WebPrint EX |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 26 Watt |
Power Consumption Standby | 0.9 Watt |
Miscellaneous | |
Included Accessories | Phone cable |
Consumables Included | 1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 46.3 cm |
Depth | 38.9 cm |
Height | 32 cm |
Weight | 12.1 kg |
Environmental Parameters | |
Sound Emission | 56 dBA (operating) |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
