We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
D-Link 24 PoE ports + 4 SFP ports Managed L2 Metro Ethernet Gigabit Switch.
Product Description | D-Link DGS 3000-28LP - switch - 24 ports - Managed - rack-mountable | Device Type | Switch - 24 ports - Managed - stackable | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 (PoE) + 4 x SFP | Power Over Ethernet (PoE) | PoE | PoE Budget | 193 W | Performance | Switching capacity: 56 Gbps , Forwarding performance (64-byte packet size): 68.45 Mpps | MAC Address Table Size | 16K entries | Routing Protocol | IGMPv2, IGMP, IGMPv3 | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH | Features | Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, half duplex mode, full duplex mode, Dying Gasp support, ACL support, QoS, MLD snooping, Safeguard Engine, IPv4 support, LLDP support, RSPAN, CoS, D-Link SIM, ToS, DSCP support, ERPS, 1.5MB packet buffer, ARP inspection, 6KV Surge protection, AAA, VLAN mirroring, WAC, CFM, LLDP-MED, Guest VLAN | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ae | Dimensions (WxDxH) | 44 cm x 21 cm x 4.4 cm | Weight | 2.54 kg |
General | |
Encryption Algorithm | SSL, SSL 3.0, SSL 2.0 |
Authentication Method | RADIUS, TACACS, TACACS+ |
Status Indicators | Power, RPS (Redundant Power Supply), fan, console, link/activity/speed |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 , 4 x SFP , 1 x console RJ-45 management |
Miscellaneous | |
MTBF | 304,565 hours |
Compliant Standards | VCCI, C-Tick, BSMI, cUL, CB, FCC, IEEE 802.3af, IEEE 802.3at |
Dimensions & Weight | |
Width | 44 cm |
Depth | 21 cm |
Height | 4.4 cm |
Weight | 2.54 kg |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
