The 5-Port Gigabit Easy Desktop Switch (GO-SW-5G) offers an economical way for SOHO and small to medium businesses benefit from the increased bandwidth of Gigabit Ethernet. It provides Gigabit ports for easy expansion of your network and a quick way to upgrade your network to Gigabit connectivity.
Product Description | D-Link GO-SW-5G - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 5 x 10/100/1000 | Performance | Switching capacity: 10 Gbps | MAC Address Table Size | 2K entries | Jumbo Frame Support | 9216 bytes | Features | Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Jumbo Frames support, Green Ethernet | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az | Environmental Standards | ENERGY STAR Qualified | Dimensions (WxDxH) | 9.7 cm x 7.9 cm x 2.8 cm | Weight | 105 g | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Type | Desktop |
Status Indicators | Port transmission speed, power, link/activity |
Expansion / Connectivity | |
Interfaces | 5 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
ENERGY STAR Certified | Yes |
Miscellaneous | |
MTBF | 815,700 hours |
Compliant Standards | FCC Class B certified, UL, VCCI Class B ITE, cUL, ICES-003 Class B, C-Tick Class B, CCC, WEEE, ANATEL, LVD |
Dimensions & Weight | |
Width | 9.7 cm |
Depth | 7.9 cm |
Height | 2.8 cm |
Weight | 105 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
