We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
28-Port Gigabit Layer 2 Managed Max PoE Switch including 4 x 10GE SFP+ ports. The DGS-3000 Series Gigabit L2 Managed Switches feature a variety of ports, including 10/100/1000BASE-T RJ-45 ports, 1G SFP ports, and 10G SFP+ ports for increased network bandwidth. Surge protection, advanced Layer 2 functions, and a suite of security and management tools make the DGS-3000 Series Gigabit L2 Managed Switches ideal for Metro Ethernet and campus applications.
Product Description | D-Link DGS 3000-28XMP - switch - 24 ports - Managed - rack-mountable | Device Type | Switch - 24 ports - Managed - stackable | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 24 x 10/100/1000 + 4 x 10Gb Ethernet SFP+ | Performance | Switching capacity: 128 Gbps , Forwarding performance (64-byte packet size): 95.24 Mpps | MAC Address Table Size | 16K entries | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH | Features | Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, Dying Gasp support, QoS, Safeguard Engine, NAP, LLDP support, RSPAN, CoS, D-Link SIM, ERPS, 2 fans, 1.5MB packet buffer, 6KV Surge protection, VLAN mirroring, WAC, CFM, Extensive ACL support, Guest VLAN | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.1AX | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 30.8 cm x 4.4 cm | Weight | 4.25 kg |
General | |
Status Indicators | Power, RPS (Redundant Power Supply), fan, console, link/activity/speed |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Included Accessories | 4 rubber feet |
Cables Included | 1 x console cable |
Rack Mounting Kit | Included |
MTBF | 268,693 hours |
Compliant Standards | VCCI, C-Tick, BSMI, cUL, IEC 61000-4-5, CB, FCC, ITU-T G.8032 |
Dimensions & Weight | |
Width | 44 cm |
Depth | 30.8 cm |
Height | 4.4 cm |
Weight | 4.25 kg |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
