Multifunctional: The CX37DN allows medium-to-large workgroups to print in A4 double-sided, plus copy and scan in colour and mono and offers fax functionality too.
Productive: It also features an automatic document feeder as standard, while an optional additional paper tray allows workgroups to save time by quickly and easily increasing paper capacity.
High-performance: Users benefit from a fast print and copy speed of up to 24ppm, as well as a maximum duty cycle of up to 120,000 pages per month, while professional-quality printing is easily achieved with AcuBrite toner technology.
Easy integration: Featuring PCL6 and PS3 emulations, IPv6 and 802.1x support, plus gigabit Ethernet connectivity, the CX37DNF is designed to fit into complex IT environments. Further increase performance by adding optional HDD and memory devices.
Low TCO: Affordable hardware, combined with long-lasting toner supplies that allow users to optimise cost per page, means total cost of ownership is extremely low. It is ENERGY STAR-qualified for reduced power consumption and environmental impact.
Product Description | Epson AcuLaser CX37DNF - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Laser (colour) | Monthly Duty Cycle (max) | 120000 impressions | Max Copying Speed | Up to 24 ppm (mono) / up to 24 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 24 ppm (mono) / up to 24 ppm (colour) | Max Printing Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Scanning | 600 x 600 dpi | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | Legal (216 x 356 mm) (max) | Standard Media Capacity | 350 sheets | Max Media Capacity | 850 sheets | Bypass Feeder Capacity | 100 sheets | Output Trays Capacity | 150 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, USB host | Office Machine Features | Save to USB flash drive, scan to e-mail | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 44.7 cm x 55.8 cm x 49 cm | Weight | 27.7 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Fax Type | Plain paper |
Printing Technology | Laser - colour |
Memory | |
Standard Memory | 256 MB 256 MB |
Max Supported Memory | 768 MB 768 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Printing | |
Printer Drivers / Emulations | PCL 6, PostScript 3, PCL 5c |
Automatic Duplexing | Yes |
First Print Out Time B/W | 16 sec |
First Print Out Time Colour | 16 sec |
Scanning | |
Optical Resolution | 600 x 600 dpi |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
PC Faxing | Yes (send only) |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 220 station(s) |
Features | Automatic redialing, group dialling |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Max Media Size | Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 210 g/m² |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm) |
Document & Media Handling Details | Input tray - 250 sheets , Bypass tray - 100 sheets , ADF - 35 sheets |
Speed Details | Copying: up to 24 ppm - B/W , Copying: up to 24 ppm - colour , Printing: up to 24 ppm - B/W , Printing: up to 24 ppm - colour |
Connections | |
Interfaces | 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN |
Network Protocols | TCP/IP, AppleTalk, IPP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, HTTPS, IPv4, IPv6, FTP, SMTP, DHCP, BOOTP |
Security Protocols & Features | SSL, TLS, IPsec, 802.1x |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 500 Watt |
Power Consumption Standby | 140 Watt |
Power Consumption Sleep | 34 Watt |
Miscellaneous | |
Warm-Up Time | 37 sec |
First Copy Out Time B/W | 11 sec |
First Copy Out Time Colour | 16 sec |
Compliant Standards | EN 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class B, EN 60950-1, EN 60825-1 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Dimensions & Weight | |
Width | 44.7 cm |
Depth | 55.8 cm |
Height | 49 cm |
Weight | 27.7 kg |
Environmental Parameters | |
Sound Emission | 33 dBA (idle) / 53.5 dBA (operating) |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 15 - 85% |
