1ST IMPACT PACKAGED PRINTER * PS, NES; Parallel; Epson Cool White (ECW); Power Supply.
Product Description | Epson TM U220PB - receipt printer - two-colour (monochrome) - dot-matrix | Printer Type | Receipt printer - dot-matrix - 9 pin - two-colour (monochrome) | Weight | 2.5 kg | Max Media Size | Roll (7.6cm) | Max Media Size (Custom) | 76 mm | Print Speed | Up to 6 lines/sec - max speed | Max Resolution (B&W) | 17.8 cpi | Cutter | Yes | Interface | Parallel | Language Simulation | EPSON ESC/POS | Media Type | Receipt paper | Total Media Capacity | 1 roll | Enclosure Colour | Cool white | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 16 cm x 24.8 cm x 13.9 cm |
General | |
Printer | |
Print Speed | Up to 6 lines/sec - max speed - 16 cpi |
Built-in Devices | Cutter |
Connectivity Technology | Wired |
Character Sizes (mm) | 1.2 x 3.1 mm, 1.6 x 3.1 mm |
Columns | 33, 35, 40, 42 |
Auto Cutter | Yes |
Repeating Printing | 1 copy |
Media Handling | |
Media Sizes | Roll (7 cm), Roll (7.6cm), Roll (5.8 cm) |
Media Thickness Range | 0.06 mm - 0.085 mm |
Roll Maximum Outer Diameter | 83 mm |
Media Feeders | 1 x manual - 1 roll - Roll (7.6cm) |
Expansion / Connectivity | |
Expansion Slots | 1 x expansion slot |
Connections | 1 x parallel |
Miscellaneous | |
Mounting Kit | Optional |
MTBF | 180,000 hour(s) |
Features | Wall mountable |
Compliant Standards | FCC Class A certified, CSA, UL, TUV, EN 60950, VCCI Class A ITE, EN55024, EN55022 Class B, AS/NZ 3548 Class B |
Power | |
Power Device | Power adapter - external |
Power Consumption Operational | 31 Watt |
Power Consumption Stand by / Sleep | 2.2 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% |
Dimensions & Weight | |
Width | 16 cm |
Depth | 24.8 cm |
Height | 13.9 cm |
Weight | 2.5 kg |
