Compact yet mighty
The compact yet feature rich WF-4720DWF is proof that great things can come in small packages. Its stylish design includes a 6.8cm touchscreen.
Business features that matter
Rely on the WF-4720DWF for top quality, laser-like prints thanks to Epson's most advanced printhead technology, PrecisionCore. Everyday tasks are easy with its 35 page automatic document feeder and 250 sheet paper tray. And share and organise documents with Scan-to: Email, Cloud, FTP and Network options
Speed up operations
Ensure your business runs smoothly with swift print speeds of 20ppm in both black and colour , and fast double-sided printing.
Low running costs
Achieve professional looking documents that are water, smudge and highlighter resistant, with Epson's DURABrite Ultra Ink. Offering great value, the inks are supplied individually, so you only ever have to replace the colour used. Plus, with XL cartridges you can print up to 2,600 black and 1,900 colour pages4.
Desk-free printing
Print from anywhere in the office with Wi-Fi connectivity or use Wi-Fi Direct to print from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer . And there's Epson's free mobile printing apps and solutions including Email print, which allows you to send items to print from almost anywhere in the world .
Product Description | Epson WorkForce Pro WF-4720DWF - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Super G3 - plain paper | Printing Technology | Ink-jet (colour) | Inkjet Technology | Epson PrecisionCore - 4-ink | Monthly Duty Cycle (max) | 25000 pages | Max Printing Speed | Up to 20 ppm (mono) / up to 20 ppm (colour) | Max Printing Resolution | Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Scanning | 1200 x 2400 dpi | Original Size | A4 (210 x 297 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper | Standard Media Capacity | 250 sheets | Output Trays Capacity | 80 sheets | Automatic Duplexing | Yes (printing) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC | AirPrint Enabled | Yes | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 42.5 cm x 37.8 cm x 24.9 cm | Weight | 9.1 kg | Manufacturer Warranty | 1-year warranty |
General | |
Fax Type | Plain paper |
Printing Technology | Ink-jet - colour |
Display Features | Touch screen |
Printing | |
Inkjet Technology | Epson PrecisionCore |
Nozzle Configuration | 800 nozzles (per cartridge) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Minimum Ink Droplet Size | 3.8 pl |
Printer Drivers / Emulations | EPSON ESC/P-R |
Ink Type | Epson DURABrite Ultra inks |
Automatic Duplexing | Yes |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 2400 dpi |
Fax Machine | |
Compatibility | Super G3 |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 180 pages |
PC Faxing | Yes |
Fax Machine Features | |
Error Correction Mode (ECM) | Yes |
Speed Dialing | 100 station(s) |
Document & Media Handling | |
Max Original Size | A4 (210 x 297 mm) |
Max Media Size | A4/Legal |
Min Media Weight | 64 g/m² |
Max Media Weight | 256 g/m² |
Supported Media Type | Envelopes, plain paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm) |
Document & Media Handling Details | Input tray - 250 sheets , ADF - 35 sheets , Output tray - 80 sheets |
Speed Details | Printing: up to 34 ppm - B/W , Printing: up to 30 ppm - colour , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Printing: up to 12 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 12 ppm (A4) - colour duplex (ISO/IEC 24734) , Scanning: 6 sec (A4) , Scanning: 12 sec (A4) |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 |
Operating System Support | MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8 64-bit |
Software Included | Drivers & Utilities |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 15 Watt |
Power Consumption Standby | 6.1 Watt |
Power Consumption Sleep | 1.2 Watt |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Dimensions & Weight | |
Width | 42.5 cm |
Depth | 37.8 cm |
Height | 24.9 cm |
Weight | 9.1 kg |
