Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO) and print up to 7,000 colour and 10,000 mono pages using, easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
The WF-8090DW uses up to 80 percent less power than competitive colour lasers thanks to its no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8090DW delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results. Scalable optional paper trays take its maximum capacity to 1,831 sheets, and the rear manual paper tray lets you print A3+ and onto a range of media.
Built for business
PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. Wi-Fi and Wi-Fi Direct allow for easy integration and printing from smartphones and tablets. Users can also securely print using a PIN code to release jobs at the printer, or by using Email Print for Enterprise4 to securely send documents directly to the printer.
Product Description | Epson WorkForce Pro WF-8090DW - printer - colour - ink-jet | Printer Type | Workgroup printer - ink-jet - colour | Weight | 25.9 kg | Inkjet Technology | Epson PrecisionCore | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Media Size Class | A3 | Max Media Size | A3 Plus (329 x 483 mm) | Print Speed | Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - colour (ISO/IEC 24734) , Up to 16 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm) | Max Resolution (B&W) | 4800 x 1200 dpi | Max Resolution (Colour) | 4800 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n) | AirPrint Enabled | Yes | Language Simulation | PCL 5E, PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7 | Media Type | Envelopes, plain paper | Total Media Capacity | 330 sheets | Media Handling | 250-sheet input tray, manual bypass slot, 80-sheet multipurpose tray | Monthly Duty Cycle (max) | 65000 pages | Networking | Print server | System Requirements | Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 56.7 cm x 57 cm x 37.8 cm |
General | |
Printer | |
Nozzle Configuration | 400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow) |
Minimum Ink Droplet Size | 3.7 pl |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Type | Epson DURABrite Pro inks |
Connectivity Technology | Wireless |
First Print Out Time B/W | 7 sec |
First Print Out Time Colour | 7 sec |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, A3 Plus (329 x 483 mm) |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm) |
Media Weight | 64 g/m² - 256 g/m² |
Media Feeders | 1 x automatic - 250 sheets , 1 x automatic - 80 sheets , 1 x manual - 1 sheet |
Max Media Capacity | 1831 sheets |
Output Trays Capacity | 250 sheets |
Duty Cycle | |
Networking | |
Remote Management Protocol | SNMP, IPP, HTTP |
Security Protocols & Features | SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, TKIP, AES, PING, Wi-Fi Direct |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) |
Power | |
Power Device | Power supply - internal |
Power Consumption Operational | 37 Watt |
Power Consumption Stand by | 8.1 Watt |
Power Consumption Sleep | 2.1 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9.x |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Environmental Parameters | |
Sound Emission (Operating) | 53 dBA |
Dimensions & Weight | |
Width | 56.7 cm |
Depth | 57 cm |
Height | 37.8 cm |
Weight | 25.9 kg |
