Make your everyday printing, scanning and copying easy with an HP DeskJet all-in-one that simply works – right out of the box. Save money with optional high-yield ink cartridges. Plus, save space with an all-in-one designed to fit where you need it.
Product Description | HP Deskjet 2130 All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Localisation | English / United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 1000 pages | Recommended Monthly Volume | 50 - 200 pages | Max Copying Speed | Up to 5 ppm (mono) / up to 3 ppm (colour) | Max Copying Resolution | Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour) | Max Printing Speed | Up to 7.5 ppm (mono) / up to 5.5 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Scanning | 1200 dpi | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Media Size | 89 x 127 mm (min) - A4 (210 x 297 mm), 215 x 279 mm (max) | Media Type | Plain paper, photo paper | Standard Media Capacity | 60 sheets | Output Trays Capacity | 25 sheets | Connection Availability | Yes | Interface | USB 2.0 | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 42.5 cm x 30.4 cm x 14.9 cm | Weight | 3.42 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Ink-jet - colour |
Copying | |
Maximum Copies | 9 |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Ink Cartridge Configuration | 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Min Media Size | 89 x 127 mm |
Max Media Size | A4 |
Min Media Weight | 60 g/m² |
Max Media Weight | 300 g/m² |
Supported Media Type | Plain paper, photo paper |
Supported Media Sizes | A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 215 x 279 mm |
Supported Envelope Sizes | International DL (110 x 220 mm) |
Document & Media Handling Details | Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets |
Speed Details | Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Copying: up to 5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 16 ppm (10 x 15 cm (4"x6")) - photo draft , Printing: 66 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 16 ppm (Letter A) - colour draft |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Operating System Support | Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits) |
Software Included | Drivers & Utilities |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 10 Watt |
Power Consumption Standby | 1.9 Watt |
Power Consumption Sleep | 9 Watt |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302 |
Compliant Standards | EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 42.5 cm |
Depth | 30.4 cm |
Height | 14.9 cm |
Weight | 3.42 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 47.5 cm |
Shipping Depth | 19.1 cm |
Shipping Height | 35.4 cm |
Shipping Weight | 4.48 kg |
Environmental Parameters | |
Sound Emission | 48 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
