Rely on a full-featured HP Enterprise MFP that accelerates productivity and streamlines digital workflow, safeguards business data and documents with a robust suite of top-flight security features and offers simple, efficient mobile printing.
Product Description | HP LaserJet Enterprise MFP M630f - multifunction printer - B/W | Device Type | Multifunction printer | Localisation | English, German, French, Italian, Spanish / Europe | Printing Technology | Laser (monochrome) | Monthly Duty Cycle (max) | 250000 pages | Recommended Monthly Volume | 5000 - 28000 pages | Max Copying Speed | Up to 57 ppm | Max Copying Resolution | Up to 600 x 600 dpi | Max Printing Speed | Up to 57 ppm | Max Printing Resolution | Up to 1200 x 1200 dpi | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 300 x 300 dpi, 200 x 100 dpi | Scanning | 600 x 600 dpi | Display | 8" | Original Size | 68 x 148 mm (min) - Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 100 sheets | Media Size | 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper | Standard Media Capacity | 1100 sheets | Max Media Capacity | 1100 sheets | Bypass Feeder Capacity | 100 sheets | Output Trays Capacity | 500 sheets | Automatic Duplexing | Yes (copying) Yes (printing) Yes (scanning) | Connection Availability | Yes | Interface | USB 2.0, Gigabit LAN, USB host | AirPrint Enabled | Yes | Office Machine Features | Print from USB flash drive, scan to folder | Power | AC 230 V (50Hz) | Dimensions (WxDxH) | 73.7 cm x 64.3 cm x 111 cm | Weight | 73.5 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Laser - monochrome |
Display Diagonal Size | 8" |
Display Features | Touch screen |
Memory | |
Standard Memory | 1.5 GB |
Max Supported Memory | 2 GB |
Hard Disk Drive | 320 GB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 9999 |
Automatic Duplexing | Yes |
Printing | |
Printer Drivers / Emulations | PCL 6, PostScript 3, PDF 1.7, PCL 5 |
Image Enhancement Technology | HP FastRes 1200, HP ProRes 1200 |
First Print Out Time B/W | 8.5 sec |
Scanning | |
Scan Element | CCD |
Optical Resolution | 600 x 600 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
PC Faxing | Yes |
Fax Machine Features | |
Speed Dialing | 100 station(s) |
Features | Fax forwarding, automatic redialing, junk fax barrier, auto reduction, poll receive |
Document & Media Handling | |
Min Original Size | 68 x 148 mm |
Max Original Size | Legal (216 x 356 mm) |
Min Media Size | 76 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 200 g/m² |
Supported Media Type | Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper |
Supported Media Sizes | A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm) |
Supported Envelope Sizes | International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm) |
Document & Media Handling Details | ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , 2 x input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² |
Speed Details | Printing: up to 57 ppm (A4) - B/W , Copying: up to 57 ppm (A4) - B/W , Scanning: up to 60 ppm - B/W , Scanning: up to 45 ppm - colour , Scanning: up to 60 ppm - B/W duplex , Scanning: up to 44 ppm - colour duplex , Printing: up to 39 ppm (A4) - B/W duplex |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11 |
Security Protocols & Features | SSL, TLS, IPsec, EAP-TLS, PEAP |
Operating System Support | Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2 |
Software Included | Drivers & Utilities, HP Web Jetadmin |
Power | |
Voltage Required | AC 230 V (50Hz) |
Power Consumption Operational | 970 Watt |
Power Consumption Sleep | 6.5 Watt |
Miscellaneous | |
Included Accessories | Phone cable |
Compliant Standards | EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EMC |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Dimensions & Weight | |
Width | 73.7 cm |
Depth | 64.3 cm |
Height | 111 cm |
Weight | 73.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 85.6 cm |
Shipping Depth | 76 cm |
Shipping Height | 147.4 cm |
Shipping Weight | 93.58 kg |
Environmental Parameters | |
Sound Emission | 58 dBA (operating) |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 32.5 °C |
Humidity Range Operating | 10 - 80% |
