Performance you can count on: high-volume, professional-quality, two-sided colour documents with outstanding reliability. Efficient one-touch printing and mobile printing options plus simple management help you be productive wherever work takes you.
Product Description | HP Color LaserJet Enterprise M651dn - printer - colour - laser | Printer Type | Workgroup printer - laser - colour | Weight | 39.1 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 42 ppm - black normal - A4 (210 x 297 mm) , Up to 42 ppm - colour normal - A4 (210 x 297 mm) , Up to 45 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 45 ppm - colour normal - ANSI A (Letter) (216 x 279 mm) , Up to 38 ppm - duplex - A4 (210 x 297 mm) , Up to 40 ppm - duplex - ANSI A (Letter) (216 x 279 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Max Resolution (Colour) | 1200 x 1200 dpi | Image Enhancement Technology | HP ImageREt 4800 / HP ProRes 1200 | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, USB host | Processor | 800 MHz | RAM Installed (Max) | 1.5 GB (1.5 GB) | Language Simulation | PCL 5, PostScript 3, PCL 6, PDF, URF | Media Type | Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper | Total Media Capacity | 600 sheets | Media Handling | 100-sheet multipurpose tray, 500-sheet input tray | Monthly Duty Cycle (max) | 120000 pages | Recommended Monthly Volume | 2500 - 17000 pages | Networking | Print server | Printer Features | On paper calibration technology | System Requirements | HP-UX 10.20, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, Microsoft Windows 2000, HP-UX 11.x, HP MPE/iX, HP-UX 11i, Novell NetWare 5.1 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows XP Professional x64 Edition SP3 or later, Apple MacOS X Lion 10.7, Microsoft Windows 7 (32/64 bits) SP1 or later, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Apple OS X 10.9 Mavericks | Dimensions (WxDxH) | 55 cm x 52 cm x 45.5 cm |
General | |
Printer | |
Built-in Devices | 4.3 inch LCD touch screen |
Connectivity Technology | Wired |
PostScript Support | Standard |
First Print Out Time B/W | 9 sec |
First Print Out Time Colour | 9 sec |
Fonts Included | 105 x TrueType , 92 x scalable PostScript |
Processor | |
RAM | |
RAM Installed (Max) | 1.5 GB / 1.5 GB (max) |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm) |
Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Media Weight | 60 g/m² - 220 g/m² |
Media Feeders | 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² |
Max Media Capacity | 3100 sheets |
Output Trays Capacity | 500 sheets |
Duty Cycle | |
Networking | |
Network Controller Name | HP Jetdirect |
Remote Management Protocol | SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPPS |
Security Protocols & Features | Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) |
Features | Security lock slot (cable lock sold separately) |
Compliant Standards | FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, IEC 60825-1:2007, EN 62479:2010, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011 |
Security Slot Type | Kensington security slot |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 650 Watt |
Power Consumption Stand by | 67 Watt |
Power Consumption Sleep | 8.5 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, HP Web JetAdmin |
OS Required | HP-UX 10.20, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, Microsoft Windows 2000, HP-UX 11.x, HP MPE/iX, HP-UX 11i, Novell NetWare 5.1 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows XP Professional x64 Edition SP3 or later, Apple MacOS X Lion 10.7, Microsoft Windows 7 (32/64 bits) SP1 or later, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Apple OS X 10.9 Mavericks |
Environmental Standards | |
Blue Angel | Yes |
ENERGY STAR | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% |
Sound Emission (Idle) | 34 dBA |
Sound Emission (Operating) | 55 dBA |
Dimensions & Weight | |
Width | 55 cm |
Depth | 52 cm |
Height | 45.5 cm |
Weight | 39.1 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 75 cm |
Depth (Shipping) | 67.8 cm |
Height (Shipping) | 59.7 cm |
Weight (Shipping) | 44.6 kg |
