Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Count on productivity and unparalleled multi-level security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Product Description | HP PageWide Enterprise Color 556xh - printer - colour - page wide array | Printer Type | Workgroup printer - page wide array - colour | Weight | 28.8 kg | Localisation | English, German, French, Italian, Spanish / Europe | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, black | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm) | Max Resolution (B&W) | 1200 x 1200 dpi | Max Resolution (Colour) | 2400 x 1200 dpi | Automatic Duplexing | Yes | Interface | USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host | AirPrint Enabled | Yes | Preview Screen Size | 4.3" | Processor | 1.2 GHz | RAM Installed (Max) | 1.25 GB (2.25 GB) | Hard Drive | 320 GB | Language Simulation | PCL 5, PostScript 3, PCL 6, PDF 1.4 | Media Type | Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper, satin photo paper | Total Media Capacity | 1050 sheets | Media Handling | 2x 500-sheet input trays, 50-sheet multipurpose tray | Monthly Duty Cycle (max) | 80000 pages | Recommended Monthly Volume | 2000 - 7500 pages | Networking | Print server | Printer Features | Hard Disk Drive Encryption | System Requirements | UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple OS X 10.9 Mavericks, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Windows 10 Mobile | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 53 cm x 46.3 cm x 59.7 cm |
