The Juice 3 Charge Power Bank with 10,000mAh (Three Full Charges) battery capacity. The perfect accessory for a day or two off the grid – if you know you'll be without mains power for your little staycation or special trip away this year, don't forget to pack the Juice 3 Charge Power Bank to make sure all your devices are powered up. Don't want to miss the perfect photo op!
The Juice 3 charges an average smartphone from 0-50% battery in only fifty minutes and holds three complete charges of an average smartphone. With a digital battery level display to check remaining energy levels – you should never get caught out!
Oh, and if you're feeling generous the Juice 3 Charge Power Bank allows you to charge two devices at once. So, if you have a friend in need you can always give them a quick power boost whilst you both charge up.
All Juice Power Banks come with a 12month warranty.
Specifications:
Input 1: Micro USB DC5V/2A
Input 2: Type C DC5V/2A
Output 1: USB A DC 5V/2. 1Amp (max)
Output 2: TYPE C DC 5V/2. 4Amp (max)
Total Output: DC 5V/2. 4Amp (max)
CE Certified
Dimensions
W x D x H (cm): 9.3 x 6 x 2.5
Product Description | Juice 3 power bank - USB, USB-C | Product Type | Power bank | Dimensions (WxDxH) | 6 cm x 3 cm x 9 cm | Weight | 195 g | Colour | Black | Output Connector Type | USB, USB-C | Voltage Required | DC 5 V | Voltage Provided | DC 5 V | Max Electric Current | 2.4 A | Battery | 10000 mAh - 37 Wh | Power Device Details | - 4 pin USB Type A - 5 V - 2.1 A , - 24 pin USB-C - 5 V - 2.4 A |
General | |
Designed For | Mobile phone |
Width | 6 cm |
Depth | 3 cm |
Height | 9 cm |
Weight | 195 g |
Enclosure Colour | Black |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B, 24 pin USB-C |
Input Connectors Qty | 2 |
Output connectors | 4 pin USB Type A, 24 pin USB-C |
Power Device Details | 4 pin USB Type A - 5 V - 2.1 A , 24 pin USB-C - 5 V - 2.4 A |
Battery | |
Capacity | 10000 mAh - 37 Wh |
Features | Charged, battery level indicator |
