Juice Super Fast 2 Port 18W Wall Charger with "PD" technology.
Charge 2 devices at once via the USB-C port and USB-A port.
Sure Grip band to help pull out of wall sockets.
Super smart and safe - detects your device and delivers the optimum charge.
Built with over current, over voltage, overload and short circuit protection.
CE certified.
Input: 110-240V. USB-A port output: 5V/3A, 9V/2A, 12V/1. 5A; USB-C port output: 5V/3A, 9V/2A, 12V/1. 5A, 18W Max Output.
Compatibility: All mobiles, tablets and laptops and USB-A devices including mobiles and tablets when using a USB-A cable.
Product Description | Juice Super power adapter - USB, USB-C - 18 Watt | Product Type | Power adapter | Dimensions (WxDxH) | 5 cm x 6 cm x 5 cm | Weight | 82 g | Colour | Black | Output Connector Type | Total 2: USB, USB-C | Voltage Required | AC 110-240 V | Voltage Provided | DC 5 / 9 / 12 V | Max Electric Current | 3.6 A | Fast Charge Technology | Power Delivery | Power Provided | 18 Watt | Power Device Details | - 4 pin USB Type A - 3 A , - 24 pin USB-C with Power Delivery - 3 A | Manufacturer Warranty | 1-year warranty with product registration |
General | |
Designed For | Tablet, mobile phone, notebook |
Width | 5 cm |
Depth | 6 cm |
Height | 5 cm |
Weight | 82 g |
Enclosure Colour | Black |
Power Device | |
Output connectors | Total 2: 4 pin USB Type A, 24 pin USB-C |
Power Device Details | 4 pin USB Type A - 3 A , 24 pin USB-C with Power Delivery - 3 A |
Features | Overload protection, short circuit protection, over voltage protection, overcurrent protection, PowerDelivery Technology, Sure Grip band |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year with product registration |
