WaterProof braided - no matter where the adventure leads, your USB Type C cable has the guts to survive. Stretched out, it's a cable. Screwed together, it's a lanyard that connects right to your gear, pack and other places.
Product Description | LifeProof LIFEACTÍV - USB-C cable - USB Type A to 24 pin USB-C - 39.8 cm | Type | USB-C cable | Features | Dust resistant, water resistant, braided, weatherproof, 5 Gbps data rate | Length | 39.8 cm | Connector | 9 pin USB Type A - male | Connector (Second End) | 24 pin USB-C - male | Rated Current | 3 A | Compliant Standards | USB 3.0 | Colour | Black | Designed For | P/N: 77-61361, 77-61362, 77-61363, 77-61386, 77-61387, 77-61388, 77-61389, 77-61399, 77-61405, 77-61406, 77-61410, 77-61489, 77-61490, 77-61491, 77-61494, 77-61495, 77-61512, 77-61513, 77-61514, 77-61515, 77-61525, 77-61530, 77-61531, 77-61532, 77-61536, 77-61642, 77-61643, 77-61644, 77-61648 |
General | |
Length | 39.8 cm |
Colour | Black |
Weight | 250 g |
Connectivity | |
Miscellaneous | |
Included Accessories | Lanyard with protective cap |
Compatibility Information | |
Designed For | P/N: 77-54826, 77-54827, 77-54828, 77-54834, 77-54859, 77-55864, 77-57862, 77-57865, 77-57870, 77-57873, 77-57970, 77-57971, 77-57973, 77-57975, 77-57979, 77-57980, 77-57982, 77-58021, 77-58024, 77-58121, 77-58203, 77-58207, 77-58211, 77-58212, 77-59154, 77-59158, 77-59379, 77-59380, 77-59403, 77-59404, 77-61361, 77-61362, 77-61363, 77-61386, 77-61387, 77-61388, 77-61389, 77-61399, 77-61404, 77-61405, 77-61406, 77-61410, 77-61489, 77-61490, 77-61491, 77-61494, 77-61495, 77-61512, 77-61513, 77-61514, 77-61515, 77-61525, 77-61530, 77-61531, 77-61532, 77-61536, 77-61642, 77-61643, 77-61644, 77-61648 |
