Wide open possibilities
Philips 43" curved 32:10 SuperWide display is like two full-size high-performance monitors in one. Productivity-enhancing features like USB-C and pop-up webcam with Windows Hello deliver the performance and convenience you expect.
32:10 SuperWide designed to replace multiscreen setups
32:10 SuperWide 43" screen, with 3840 x 1200 resolution, is designed to replace multiscreen setups for massive wide view. It's like having two 16:10 displays side by side. SuperWide monitors offer the screen area of dual monitors without the complicated setup.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time
Product Description | Philips P-line 439P9H - LED monitor - curved - 43.4" - HDR | Device Type | LED-backlit LCD monitor - 43.4" | Energy Class | Class G | Energy Consumption per Year | 100 kWh | Power Consumption (On mode) | 47 W | Curved Screen | Yes | Features | Microphone, KVM Switch, 2.0 megapixel camera, USB 3.2 Gen 1 hub, USB PD 90 Watt | Panel Type | VA | Aspect Ratio | 32:10 | Native Resolution | 3840 x 1200 at 100 Hz | Pixel Pitch | 0.274 mm | Brightness | 450 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | HDR Capable | DisplayHDR 400 | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 105% NTSC (CIE 1976), 123% sRGB (CIE 1931), 91% Adobe RGB, 95% DCI-P3 wide, 99% BT.709 | Input Connectors | HDMI, 2xDisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, 2H Hard Coating, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black texture | Dimensions (WxDxH) - with stand | 105.8 cm x 30.3 cm x 46 cm | Weight | 14.37 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, CU-EAC, BFR-free, DisplayPort 1.4, HDCP 2.2, HDCP 1.4, PVC-free |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 43.4" |
Viewable Size | 43" |
Curved Screen | Yes (1800R) |
Built-in Devices | KVM Switch, 2.0 megapixel camera, USB 3.2 Gen 1 hub |
USB Power Delivery | 90 Watt |
Panel Type | VA |
Pixel Per Inch | 93 |
HDR Certification | DisplayHDR 400 |
Vertical Refresh Rate | 48 - 100 Hz |
Horizontal Refresh Rate | 30 - 150 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Multilingual |
Features | Picture by picture, MultiView, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, Adaptive-Sync technology, EasyRead, Windows 10 Hello |
Dimensions (WxDxH) | 105.8 cm x 30.3 cm x 46 cm - with stand |
Weight | 14.37 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Input | |
Type | Microphone |
Connectivity | |
Interfaces | 2 x DisplayPort (HDCP) , HDMI (HDCP) , USB-C with Power Delivery (power up to 90W) , USB-C 3.2 Gen 1 upstream , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Headphones , Network (RJ-45) |
Mechanical | |
Tilt Angle | -5/+10 |
Swivel Angle | 40 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), DisplayPort Alt Mode |
Cables Included | HDMI cable , DisplayPort cable , USB-C cable , USB-C to USB-A cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 47 kWh/1000h |
Power Consumption HDR (On mode) | 79 kWh/1000h |
Power Consumption (Typical) | 41.8 Watt |
Power Consumption Stand by | 0.4 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Philips SmartControl |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 105.8 cm - depth: 30.3 cm - height: 46 cm - weight: 14.37 kg , Without stand - width: 105.8 cm - depth: 13.7 cm - height: 36.1 cm - weight: 10.34 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 115 cm |
Shipping Depth | 35 cm |
Shipping Height | 52.5 cm |
Shipping Weight | 20.19 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
