Seagate 4TB Expansion USB 3.0 3.5" Desktop Drive
Key features
  • The easy-to-use storage solution
  • Adds storage capacity instantly
Product codes
chevron icon
chevron icon
The Seagate Expansion desktop drive provides extra storage for your ever-growing collection of files. Add space for more files instantly, consolidate all your files to a single location, or free up space on your computer's internal drive for improved performance. Set-up is straightforward. Simply plug in the included power supply and USB cable and you are ready to go. It is automatically recognized by the Windows operating system, so there is no software to install and nothing to configure. Saving files is easy too: just drag and drop. Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a SuperSpeed USB 3.0 port. USB 3.0 is backward compatible with USB 2.0 for additional system compatibility.
chevron icon
Product Description Seagate Expansion Desktop STBV4000200 - hard drive - 4 TB - USB 3.0
Type Hard drive - external (desktop)
Capacity 4 TB
Interface USB 3.0
Power Source Included AC adapter
Dimensions (WxDxH) 118 mm x 179.5 mm x 37.5 mm
Weight 940 g
Localisation EMEA
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
