Charge or Sync your Micro USB device or Samsung Galaxy Tab using a single cable. The USB2UBSDC 0.65m/2 ft Samsung Galaxy Tab Dock Connector/Micro USB to USB Combo Cable offers a simple and reliable solution for connecting your Micro USB device or your Samsung Galaxy Tab to your computer, for charging or syncing.
This convenient cable features a Samsung Galaxy Tab dock connector as well as a Micro USB connector on one end, and a USB connector on the other, providing the option to charge or dock either a Samsung Galaxy Tab or a Micro-USB-equipped device, using a single, handy cable.
The USB2UBSDC is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced sync cables.
Product Description | StarTech.com 65cm Samsung Galaxy Tab Dock Connector Micro USB to USB Cable - charging / data cable kit - 65 cm | Cable | Charging / data cable kit | Technology | Double shielded | American Wire Gauge (AWG) | 28 | Length | 65 cm | Colour | Black | Features | Sync and charge | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ST7C51224, ST7C51224EU, ST7CU35122 |
General | |
Cable Type | Charging / data cable kit |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 65 cm |
Plated Connector | Nickel |
Recommended Use | Tablet |
Colour | Black |
Details | |
Included Qty x Type | USB cable - 4 PIN USB Type A (male) to 5 pin Micro-USB Type B (male) , Tablet charging / data adapter - Samsung 30-pin Dock Connector (male) to 5 pin Micro-USB Type B (female) |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
