Add a parallel port to your low profile/small form factor computer through a PCI expansion slot. The PCI1P LP 1 Port Low Profile PCI Parallel Adapter Card adds one IEEE 1284 port to your small form factor PC, with data transfer speeds of up to 2.7 Mbps - up to 3 times faster than on-board parallel ports. The adapter card features a low profile design that is suited to small form factor computer cases, while including a full height bracket to adapt to any installation.
Installation is a breeze with plug and play support and drivers for Windows 7, Vista, XP, ME, 2000, 98, 95, NT4, DOS and Linux . IRQ sharing and hot swapping capabilities guarantee convenient, hassle-free connections to any parallel peripheral.
Product Description | StarTech.com 1 Port Low Profile PCI Parallel Adapter Card - Parallel adapter - PCI low profile - IEEE 1284 - PCI1P_LP - parallel adapter - PCI - IEEE 1284 | Device Type | Parallel adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI | Ports | IEEE 1284 | Data Link Protocol | Parallel | Data Transfer Rate | 1.5 Mbps | System Requirements | Microsoft DOS, Microsoft Windows 95/98, Linux, Microsoft Windows Millennium Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits) | Manufacturer Warranty | Limited lifetime warranty |
General | |
Networking | |
Ports | IEEE 1284 |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female - 1 |
Compatible Slots | 1 x PCI - low-profile |
Miscellaneous | |
Compliant Standards | Plug and Play |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft DOS, Microsoft Windows 95/98, Linux, Microsoft Windows Millennium Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - lifetime |
