Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40km over Single Mode LC fiber. The ET1000S40LC2 1000 Mbps Gigabit Single-Mode Fiber Media Converter (LC, 40 km) enables you to extend a Gigabit Ethernet network over single-mode fiber, at distances up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description | StarTech.com 1000 Mbps Gigabit Single-Mode Copper to Fiber Media Converter - Ethernet (1000Base-T) to LC Fiber Converter (ET1000S40LC2) - fibre media converter - 1GbE | Device Type | Fibre media converter - RJ-45 / LC single-mode | Form Factor | External | Localisation | North America, United Kingdom, Europe | Cabling Type | 1000Base-LX, 1000Base-SX, 1000Base-T | Data Transfer Rate | 1 Gbps | Optical Wave Length | 1310 nm | Data Link Protocol | 1GbE | Max Transfer Distance | 40 km | Power | AC 120/230 V | Dimensions (WxDxH) | 9.5 cm x 16 cm x 2 cm | Weight | 0.62 kg | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA12M2NEUA, SVA12M5NA |
General | |
Device Type | Fibre media converter |
Colour | Black |
Networking | |
Connectivity Technology | Wired |
Features | Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC single-mode female x 2 |
Miscellaneous | |
MTBF | 65,000 hours |
Compliant Standards | Plug and Play, FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Dimensions & Weight | |
Width | 9.5 cm |
Depth | 16 cm |
Height | 2 cm |
Weight | 0.62 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Compatibility Information | |
