ITEM | QTY | PRICE |
StarTech.com 6 ft 3.5mm Stereo Audio...
3 | £16.44 |
Connect a PC directly to a multimode ST fiber network through an available PCI slot. The PCI100MMST 100 Mbps Fiber Optic (MM ST) PCI Ethernet Adapter Card offers the perfect "Fiber-to-the-desk" solution allowing you to add a multimode ST fiber port to your system through an available standard or low-profile PCI slot.
A simple solution for connecting a computer directly to a fiber network, the Fiber Ethernet Adapter card can be installed in the computer through any PCI slot and is perfectly suited for high bandwidth applications with support for Full Duplex operation and 10/100 Mbps transfer speeds at distances of up to 2km.
Ideal for secure network setups, the PCI100MMST offers a direct fiber connection which is not susceptible to electronic interference like standard RJ45 networks.
Product Description | StarTech.com 100Mbps PCI Multi Mode ST Fiber Ethernet NIC Network Adapter 2km - network adapter - PCI-X - 10/100 Ethernet | Device Type | Network adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI-X / 133 MHz | Ports | 10/100 Ethernet | Dimensions (WxDxH) | 5.6 cm x 12.1 cm x 1.8 cm | Cabling Type | Ethernet 100Base-FX | Data Link Protocol | 10Mb LAN, 100Mb LAN | Data Transfer Rate | 100 Mbps | Compliant Standards | IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x | Manufacturer Warranty | 1-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-FX - ST multi-mode |
Compatible Slots | 1 x PCI-X / 133 MHz |
Miscellaneous | |
Compliant Standards | FCC |
Dimensions & Weight | |
Width | 5.6 cm |
Depth | 12.1 cm |
Height | 1.8 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 5 - 95% |
