Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM15FL 15-foot Flat High Speed HDMI Cable with Ethernet supports Ethernet data interconnectivity with compatible HDMI devices and features a flat-shaft design that makes it suitable for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
Product Description | StarTech.com 15 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - Flat HDMI Cable (HDMIMM15FL) - HDMI cable with Ethernet - 4.6 m | Cable | HDMI cable with Ethernet | American Wire Gauge (AWG) | 28 | Length | 4.6 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | HDMI cable with Ethernet |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 4.6 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
