We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Turn a 3.5" SATA Hard Drive into a UASP-supported USB 3.0 External Hard Drive. The S3510BMU33 Black USB 3.0 Hard Drive Enclosure with UASP lets you connect a 3.5in SATA III hard drive (HDD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 3.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD enclosure is compatible with virtually any 3.5in SATA hard drive, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0/SATA III enclosure features high quality aluminum construction, ensuring durability.
Product Description | StarTech.com 3.5in Black Aluminum USB 3.0 External SATA III SSD / HDD Enclosure with UASP for SATA 6Gbps - 3.5" SATA Hard Drive Enclosure (S3510BMU33) - storage enclosure - SATA 6Gb/s - USB 3.0 | Device Type | Storage enclosure - external | Bus Type | USB 3.0 | Colour | Black | Expansion Bays | 1 x internal - 3.5" | Hard Drive Form Factor Compatibility | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Hard drive | Max Storage Devices Qty | 1 | Product Material | Plastic, aluminium | Power Source | Included AC adapter | Power | AC 120/230 V | System Requirements | Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits) | Dimensions (WxDxH) | 3.14 cm x 19.15 cm x 11.54 cm | Weight | 319.8 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA12M2NEUA, SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17 |
