The StarTech.com 3 ft. USB Cable is a high quality fully rated USB cable with the A-B Male-to-Male type connection. Typical applications for this cable are to connect from a PC or Mac to a USB peripheral like a printer, scanner, USB hub, etc. This cable is fully molded and manufactured to the USB V1.1 specifications.
Product Description | StarTech.com 3 ft Beige A to B USB 2.0 Cable - M/M - USB cable - USB (M) to USB Type B (M) - 3 ft - molded - USBFAB_3 - USB cable - USB to USB Type B - 0.9 m | Type | USB cable | Features | Molded | Length | 0.9 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type B - male | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | USB cable |
Features | Molded |
Length | 0.9 m |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
The following resources are available for the StarTech.com 3 ft Beige A to B USB 2.0 Cable - M/M
