Add 4 high-speed RS-232 serial ports to your PC through a low profile PCI Express expansion slot. The PEX4S952LP 4 Port Low Profile Native RS232 PCI Express Serial Card (16950 UART) turns a PCI Express slot into four RS232 (DB9) serial connections.
The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, and ships with a half-height/low profile bracket installed, but also includes an optional full profile bracket that lets you add four serial ports to virtually any computer (regardless of the case form factor).
Product Description | StarTech.com Replaced by PEX4S953LP - 4 Port Low Profile Native RS232 PCI Express Serial Card (PEX4S952LP) - serial adapter - PCIe - RS-232 x 4 | Device Type | Serial adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express x1 | PCI Specification Revision | PCIe 1.0a | Ports | RS-232 x 4 | Dimensions (WxDxH) | 2 cm x 9 cm x 8 cm | Weight | 58 g | Data Link Protocol | RS-232 | Data Transfer Rate | 460.8 Kbps | Processor | 1 x Oxford Semiconductor OXPCIe954 | System Requirements | Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP | Manufacturer Warranty | Limited lifetime warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Features | Software flow control |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 4 x RS-232 - 9 pin D-Sub (DB-9) (on cable) |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Compliant Standards | WHQL, FCC, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Vista / 2000 / XP |
Dimensions & Weight | |
Width | 2 cm |
Depth | 9 cm |
Height | 8 cm |
Weight | 58 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 85 °C |
Humidity Range Operating | 5 - 85% |
