This 6ft USB 2.0 cable features two USB 'A' male connectors, delivering a dependable way to connect your PC to a USB hub, or connect USB 2.0 peripherals to a USB hub.
Product Description | StarTech.com 6 ft Beige A to A USB 2.0 Cable - M/M - USB cable - USB (M) to USB (M) - 6 ft - beige - USBFAA_6 - USB cable - USB to USB - 1.8 m | Type | USB cable | Length | 1.8 m | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type A - male | Colour | Beige | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ST4200MINI2 |
General | |
Type | USB cable |
Length | 1.8 m |
Colour | Beige |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
