Connect to your external solutions and transfer data at 10x the speed of USB 2.0. StarTech.com's 6ft Black SuperSpeed USB 3.0 cable (A-B, male-male) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, the 6ft USB 3.0 cable offers a throughput of up to 5Gbps when used with a USB 3.0 host and device - an astounding 10x the capability of USB 2.0 (480Mbps).
The 6ft USB 3.0 cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication.
Product Description | StarTech.com 6 ft / 2m Black SuperSpeed USB 3.0 Cable A to B - USB 3 A (m) to USB 3 B (m) (USB3SAB6BK) - USB cable - USB Type A to USB Type B - 1.8 m | Type | USB cable | Technology | Shielded twisted pair (STP) | Features | Molded, 5 Gbps data rate | Length | 1.8 m | Connector | 9 pin USB Type A - male | Connector (Second End) | 9 pin USB Type B - male | Compliant Standards | USB 3.0 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | StarTech.com 4-Port Industrial USB 3.0 5Gbps Hub, Rugged USB Hub w/15kV Air/8kV Contact ESD and Surge Protection, DIN/Wall/Desk Mountable USB-A Hub, USB Expansion Hub with Locking Ports - Metal Construction (5G4AINDNP-USB-A-HUB) |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 28 |
Length | 1.8 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 3.0, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
