We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Connect your VGA monitor to a DisplayPort-equipped computer using a single cable. The DP2VGAMM6 6ft DisplayPort to VGA (M-M) Cable lets you connect a VGA capable display to a DisplayPort video card/source. The cable provides a connection distance of 6 feet and features a male VGA connector and a male DisplayPort connector.
The DisplayPort to VGA adapter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your VGA display, while using a cutting edge DisplayPort video source.
Product Description | StarTech.com 6ft DisplayPort to VGA Cable – 1920x1200 - M/M – DP to VGA Adapter Cable for Your Computer Monitor or Display (DP2VGAMM6) - DisplayPort cable - 1.83 m | Type | DisplayPort cable | Length | 1.83 m | Connector | DisplayPort - male | Connector (Second End) | HD-15 (VGA) - male | Compliant Standards | FCC, RoHS | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Length | 1.83 m |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
