We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Maximize cost-savings and network performance with this bulk pack of single-mode/multi-mode Mini-GBIC modules. Perfect for large-scale deployments or installations on multiple devices, this bulk pack of Gigabit fiber SFPs provides maximum cost savings. Built to exacting specifications and fully tested to ensure maximum performance, these high-quality transceiver modules can be installed into Cisco switches and routers that support the GLC-LH-SMD transceiver module, as well as other major brands of networking equipment.
The SFP transceivers provide a dependable and cost-effective way to add, replace or upgrade the Gigabit fiber ports on your 1000Base-LX/LH networking equipment, and they're backed by a lifetime warranty.
The SFP transceivers included in this 10-pack are manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com produces an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
These Gigabit single-mode SFPs are engineered to the highest quality standards and are 100% Cisco compatible, equivalent to the Cisco GLC-LH-SMD SFP transceiver. StarTech.com SFP transceivers are configured and fully tested to ensure they work seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, these Gigabit fiber transceivers are fully hot-pluggable which enables you to install them without interrupting network traffic or having to reboot your equipment. They provide a versatile and cost-effective solution that's compatible with a multitude of Gigabit fiber networking devices.
Ideal for use in switches, routers and other networking equipment, the SFPs provide reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFPs support auto-negotiation, a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 1.25Gbps.
You can count on GLCLHSMD10ST for reliable performance.
Product Description | StarTech.com Cisco GLC-LH-SMD Compatible SFP Module, 1000BASE-LX/LH, 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 1GE Gigabit Ethernet, LC Connector, 10km 1310nm, Firepower, ASR920 - Lifetime Warranty (GLCLHSMD10ST) - SFP (mini-GBIC) transceiver module - 1GbE | Device Type | SFP (mini-GBIC) transceiver module - LC | Packaged Quantity | 10 (specifications are for single item) | Form Factor | Plug-in module | Cabling Type | 1000Base-LX, 1000Base-LH | Data Transfer Rate | 1.25 Gbps | Optical Wave Length | 1310 nm | Data Link Protocol | 1GbE | Max Transfer Distance | 10 km | OEM Manufacturer Equivalent Part Number | Cisco GLC-LH-SMD | Manufacturer Warranty | Limited lifetime warranty |
