ITEM | QTY | PRICE |
Asus ExpertBook B1 Intel Core i3-N305...
4 | £1,585.00 |
Logitech K750 Wireless Solar Powered...
4 | £308.08 |
Poly Plantronics CS540/A with APS10 E...
1 | £162.22 |
A Superior Portable Power Station
Superior LG Battery Cell
All rechargeable batteries have a limited lifespan and the available capacity is to diminish in the cold weather.
Benefiting from advanced battery technology of superior LG battery cells, Ally series power banks reduce the self-aging helping to maximize the lifespan of power bank, and retain more available capacity in cold season.
One Is Enough
TL-PB15600 is an enormous capacity 15600mAh power bank from Ally series. The ultra high capacity working together with high energy efficiency, delivers more power and charges more times for all your devices. A TL-PB15600 carries enough power for most circumstance, even a long trip or a family gathering.
Dual Flexible Output Ports
Powered by TP-LINK Smart Charging technology, both output ports of TL-PB15600 can intelligently adjust the charging power subject to the connected devices. These flexible output ports are designed to be capable of delivering ultra fast charging power for devices with large battery like tablets, and also capable of delivering safe and minimal charging power for gadgets with tiny battery like smart wearable devices.
65% Faster Charge
The less charging time, the more you can make out of your devices. Thanks to TP-LINK Smart Charging technology and 5V/2.4A ultra fast charging speed, TL-PB15600 can charge 65% faster and save up to 40% charging time. Fully charging iPhone 6s Plus takes 150mins with TP-LINK Smart Charging, while 250mins with an original Apple charger.
2.3x Turbo Recharging Speed, Save Half of Recharging Time
Also supporting 5V/2.4A recharging speed, TL-PB15600 takes only 5.8 hours to recover from empty to full capacity. Within same time period, other 15000mAh level power bank with 5V/1A input, only recharges to 43% capacity while full recharge takes 13.3 hours.
LED Flashlight
Built-in flashlight comes in handy for in-house and off–road activities
A Safe and Reliable Power Supply
Ally sereis power banks incorporate the latest safety features to protect your devices and power bank against short circuit, over voltage, over current, over charging, over discharging and over heating.
Increased Compatibility
Compatible with smart devices running iOS, Android, Windows and most other USB-charged devices, from devices with large battery like tablets, to gadgets with tiny battery like smart wearable devices.
Product Description | TP-Link Ally Series TL-PB15600 power bank - 2 x USB | Product Type | Power bank | Dimensions (WxDxH) | 6.12 cm x 2.24 cm x 15 cm | Weight | 344 g | Output Connector Type | Total 2: 2 x USB - on cable: Micro-USB | Voltage Required | 5 V | Voltage Provided | 5 V | Max Electric Current | 3 A | Battery | 15600 mAh | Power Device Details | 2 x - 4 pin USB Type A - 5 V - 2.4 A | Cables | Micro-USB cable |
General | |
Width | 6.12 cm |
Depth | 2.24 cm |
Height | 15 cm |
Weight | 344 g |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B |
Input Connectors Qty | 1 |
Output connectors | Total 2: 2 x 4 pin USB Type A |
Detachable Cable Connector Type | Micro-USB Type B |
Power Device Details | 2 x 4 pin USB Type A - 5 V - 2.4 A |
Features | LED indicator, short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, built-in flashlight, overdischarging protection, Smart Charge Technology |
Battery | |
Capacity | 15600 mAh |
Features | Power level indicator button, battery level indicator |
Miscellaneous | |
Included Accessories | Micro USB cable |
Cables Included | Micro-USB cable |
