Powerful Capacity
Powerful capacity of 10400mAh lets you charge a smartphone 3~5 times, keeping your devices running all the time.
* Actual number of charge times depends on your device's battery size.
Simultaneously Super-fast Charging
Dual USB ports (5V/2A and 5V/1A) allow for charging two devices simultaneously. Built-in special circuit provides full speed for your smartphones.
Reliable Power
TL-PB10400's multiple protections of short circuit, over-voltage, over-current, over-charge, over-discharge, and over-heating ensure safe and reliable charging to avoid any potential harm to your devices.
High Energy Efficiency Rate
Combining high quality circuit, TL-PB10400 greatly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. So under full capacity, it can charge a smartphone for 3~5 times, ideal for extended use of mobile devices.
Practical Functions for Convenience
Smart LED Indicator: Four LED lights work as charge indicators to show battery level or charging status
Practical Flashlight: Built-in flashlight comes in handy for in-house and off-road activities
Universal Compatibility
Compatible with almost any smart devices like iPhones, iPads, Android smartphones and other 5V input USB-charged devices.
Product Description | TP-Link TL-PB10400 power bank - USB | Product Type | Power bank | Dimensions (WxDxH) | 4.43 cm x 4.43 cm x 8.88 cm | Weight | 241 g | Output Connector Type | Total 2: USB - on cable: Micro-USB | Voltage Required | 5 V | Voltage Provided | 5 V | Max Electric Current | 2 A | Battery | 10400 mAh | Cables | Micro-USB cable |
General | |
Designed For | Tablet, mobile phone |
Width | 4.43 cm |
Depth | 4.43 cm |
Height | 8.88 cm |
Weight | 241 g |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B |
Input Connectors Qty | 1 |
Output connectors | Total 2: 4 pin USB Type A |
Detachable Cable Connector Type | Micro-USB Type B |
Features | LED indicator, short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, built-in flashlight, overdischarging protection |
Battery | |
Capacity | 10400 mAh |
Max Recharge Cycles | 500 |
Miscellaneous | |
Included Accessories | Carrying pouch |
Cables Included | Micro-USB cable |
