The PoE Injector TL-POE150S fully complies with IEEE 802.3af standard, and can work with all IEEE 802.3af PoE compliant PDs (Powered Devices) or PoE receiver adapters, or other equivalent product, to expand your network to where there are no power line or outlet, where you wish to fix device such as AP, IP camera or IP phone, etc.
Product Description | TP-Link TL-POE150S - PoE injector | Device Type | PoE injector - external | Output Voltage | 48 V | Output connectors | 1 x RJ-45 | Dimensions (WxDxH) | 8.1 cm x 5.2 cm x 2.4 cm |
General | |
Power Device | |
Power Output Connectors Details | 1 x RJ-45 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 90% |
Dimensions & Weight | |
Width | 8.1 cm |
Depth | 5.2 cm |
Height | 2.4 cm |
