Outdoor 2.4GHz 300Mbps Wireless Base Station up to 30dBm 802.11b/g/n 2 ext. antenna interfaces 10/100Mbps 110/100/1000Mbps LAN Weatherproof Passive PoE
Product Description | TP-Link WBS210 - radio access point - Wi-Fi | Device Type | Radio access point | Form Factor | External - outdoor | Processor | 1 x Qualcomm MIPS 74KC 560 MHz | RAM | 64 MB | Flash Memory | 8 MB | Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 7.5 cm x 3.2 cm x 18.9 cm |
General | |
Ruggedized Design | Outdoor |
Width | 7.5 cm |
Depth | 3.2 cm |
Height | 18.9 cm |
Processor / Memory / Storage | |
Processors Installed | 1 x Qualcomm MIPS 74KC 560 MHz |
Max Supported Qty | 1 |
RAM | 64 MB DDR2 SDRAM |
Networking | |
Form Factor | External |
Connectivity Technology | Wireless |
Data Transfer Rate | 300 Mbps |
Network / Transport Protocol | PPTP, L2TP, PPPoE, DHCP |
Remote Management Protocol | SNMP 2c, HTTP, HTTPS, SSH |
Features | Repeating mode, ALG support, manageable, DFS support, Wireless Distribution System (WDS) support, Multiple SSID support, wireless bridge mode, bandwidth control, Wireless Client Mode, pole mountable, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, 15KV ESD Protector |
Encryption Algorithm | AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 , 2 x aerial - RP-SMA |
Miscellaneous | |
Compliant Standards | FCC, RoHS, IP65 |
Power | |
Power Device | Power injector |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Environmental Parameters | |
Min Operating Temperature | -30 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
