WD Elements™ desktop storage with USB 3.0 offer reliable, high-capacity, add-on storage, ultra-fast data transfer rates, universal connectivity, and 2 TB capacity. Includes a free trial of WD SmartWare™ Pro automatic backup software.
Product Description | WD Elements Desktop WDBWLG0020HBK - hard drive - 2 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 2 TB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Power Source | Included AC adapter | Dimensions (WxDxH) | 135 mm x 165.8 mm x 48 mm | Weight | 910 g | Localisation | United Kingdom | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 2 TB |
Width | 135 mm |
Depth | 165.8 mm |
Height | 48 mm |
Weight | 910 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | WD SmartWare Pro (30 days trial) |
OS Required | Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 |
Miscellaneous | |
Cables Included | 1 x USB cable - external |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | Plug and Play, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
