WD 4TB My Passport 2.5" USB 3.0 Portable Hard Drive - Red
Key features
  • Auto backup
  • Password protection
  • High reliability
  • Easy to use
Product codes
chevron icon
chevron icon
My Passport
The My Passport portable hard drive is trusted to store the massive amounts of photos, videos and music you love. Available in an array of vibrant, fun colors, the sleek style fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
- Auto backup with included WD Backup software
- Password protection with hardware encryption
- Easy and ready to use out of the box
- Bold, vibrant design in wide range of beautiful colors
- Trusted drive built with WD reliability
- Up to 4TB capacity
- USB 3.0; USB 2.0 compatible
Back Up Automatically
Equipped with WD Backup software so you can automatically back up photos, videos, music and documents. Set it to your schedule. Just pick the time and frequency.
Password Protection
Built-in 256-bit AES hardware encryption with WD Security software helps keep your content private and safe. Easily add a 'return-if-found' message as the password prompt in case your My Passport ever gets lost.
Easy to Use
My Passport portable storage is ready to use out of the box so you can start transferring files, saving your memories and backing up. It comes with all the software you need to help protect all your data, including WD Backup and WD Security software.
Reimagined Design
The sleek, vibrant design of the My Passport drive comes in a wide range of bold, beautiful colors so you can pick the one that matches your own unique, personal style.
Massive Capacity
With up to 4TB, you can take the massive amounts of photos, music and videos you love wherever you go, and have plenty of room for other important documents, too.
WD Quality Inside and Out
WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability. And we stand behind the trusted My Passport drive with a 2-year limited warranty
chevron icon
Product Description WD My Passport WDBYFT0040BRD - hard drive - 4 TB - USB 3.0
Type Hard drive - external (portable)
Capacity 4 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Password authentication, hardware encryption, automatic backup
Power Source USB bus
Enclosure Colour Red
Dimensions (WxDxH) 110 mm x 81.5 mm x 21.5 mm
Weight 250 g
Localisation Worldwide (excluding China)
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
