Marketing description is not available.
Product Description | Acer EB490QK - LED monitor - 4K - 48.5" | Device Type | LED-backlit LCD monitor - 48.5" | Energy Class | Class A+ | Energy Consumption per Year | 82 kWh | Power Consumption (On mode) | 56 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Pixel Pitch | 0.27963 mm | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 1.07 billion colours | Input Connectors | 3xHDMI, VGA, DisplayPort | Screen Coating | Semi-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - without stand | 110.85 cm x 8.1 cm x 64.13 cm | Weight | 11.7 kg | Compliant Standards | MPR II, VCCI, NEMKO, CCC, FCC, DDC/CI, RoHS, ISO 9241-307, EAC, NOM-NYCE |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 48.5" |
Panel Type | IPS |
Vertical Refresh Rate | 55 - 76 Hz |
Horizontal Refresh Rate | 24 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer Adaptive Contrast Management (ACM), 10-bit gamma, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, 6-Axis Color Adjustments, Picture-in-Picture |
Colour | Black |
Dimensions (WxDxH) | 110.85 cm x 8.1 cm x 64.13 cm - without stand |
Weight | 11.7 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 10 Watt |
Connectivity | |
Interfaces | 3 x HDMI , VGA , DisplayPort , Audio line-out |
Mechanical | |
VESA Mounting Interface | 400 x 200 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x VGA cable , 1 x DisplayPort cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 130 Watt |
Power Consumption Stand by | 450 mW |
Power Consumption (Off Mode) | 400 mW |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - weight: 12.1 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
