Wishlist updated!
LG 86" UR7800 4K Ultra HD Smart TV
You have added LG 86" UR7800 4K Ultra HD Smart TV to your Wishlist
Acer RT280Kbmjdpx 28" 3840x2160 1ms DVI HDMI DP Monitor
Key features
  • Quality visuals
  • Slender KeySellingPoints, sleek stand
  • Good for your eyes
Product codes
chevron icon
chevron icon
These displays deliver high resolution, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source. RT0 monitors feature very thin panels. Its ZeroFrame design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand. RT0 displays use Flicker-less technology to reduce eye-strain-causing screen flickering. Blue Light Filter technology lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView technology reduces the light reflected off the screen.
chevron icon
Product Description Acer RT280K - LED monitor - 4K - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class B
Energy Consumption per Year 64 kWh
Power Consumption (On mode) 44 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160
Brightness 300 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 1 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Tilt
Colour Black
Environmental Standards ENERGY STAR Qualified
Compliant Standards MPR II
chevron icon
Accessories
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
