The Full HD resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. Plus, this monitor is mercury free, making it safer for you and the environment. Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings.
Product Description | Acer V276HLCbmdpx - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 6 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | DVI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 63.97 cm x 24.2 cm x 46.34 cm | Weight | 5.2 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | RoHS, TUV Rheinland | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | VA |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 31 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 6-bit gamma, 72% NTSC colour gamut |
Dimensions (WxDxH) | 63.97 cm x 24.2 cm x 46.34 cm - with stand |
Weight | 5.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DVI , VGA , DisplayPort , Audio line-out (mini-jack) |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Included Accessories | Stand |
Cables Included | 1 x VGA cable - VGA to VGA - 1.5 m |
MTBF | 30,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 26.6 Watt |
Power Consumption Stand by | 0.24 Watt |
Power Consumption Sleep | 0.43 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 63.97 cm - depth: 24.2 cm - height: 46.34 cm - weight: 5.2 kg , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in |
