ITEM | QTY | PRICE |
Epson 79XL Black Ink Cartridge
2 | £86.44 |
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating Windows on the screen. It can activate via a hotkey on monitor and used as a guide to accurately view and edit photos.
Product Description | ASUS VW22ATL - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Energy Class | Class A+ | Energy Consumption per Year | 25 kWh | Power Consumption (On mode) | 17.1 W | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Speakers | Integrated | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) | 60.1 cm x 17.5 cm x 48.7 cm | Weight | 7 kg | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, contrast, colour temperature |
Features | HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode |
Colour | Black |
Weight | 7 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | DVI-D (dual link) , VGA , Audio line-in |
Mechanical | |
Tilt Angle | -5/+15 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable , 1 x VGA cable , 1 x audio cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 33 Watt |
Power Consumption Stand by / Sleep | 0.5 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.3 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
