The USB-C to HDMI adapter provides a smooth and effortless experience for connecting your USB-C-enabled device to your HDTV, 4K/Ultra HDTV, or any other HDMI-enabled display. This adapter supports 4K @ 60hz, providing stunning clarity and sound for the ultimate viewing experience.
Product Description | Belkin adapter - USB-C / HDMI | Cable | Adapter - USB-C / HDMI | Max Output Resolution | 4096 x 2160 - 60 Hz | Connector | 24 pin USB-C - male | Connector (Second End) | HDMI - female | Compliant Standards | Thunderbolt 3 | Features | 4K support | Works With Chromebook | Yes |
General | |
Cable Type | Adapter 4K support |
Interface Supported | USB-C / HDMI |
Features | HDCP compliant |
Adapters & Converters | |
Max Output Resolution | 4096 x 2160 |
Refresh Rate | 60 Hz |
Connectivity | |
Connector (Second End) | 19 pin HDMI Type A - female |
Miscellaneous | |
Compliant Standards | HDCP 2.2 |
