This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
Product Description | C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 0.5 m - grey | Type | Patch cable - CAT 6a | Technology | Shielded twisted pair (STP) | Wires per Cable | 8 wires | Features | Molded, snagless, stranded | Length | 0.5 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6a |
Pairs per Cable | 4 pairs |
Length | 0.5 m |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS - up to 600 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
