For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
Product Description | C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - grey | Type | Patch cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Features | Molded, snagless, stranded | Length | 10 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey |
General | |
Network Cable Type | Patch cable - CAT 6 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Plated Connector | Gold |
Length | 10 m |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS - up to 550 MHz |
