For voice/data/video distribution, this cable will handle bandwidth-intensive applications. Meets all Cat5E TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL).
Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
Constructed from high-quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
Product Description | C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 1 m - white | Type | Patch cable - CAT 5e | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Stranded, uniboot | Length | 1 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | White |
General | |
Network Cable Type | Patch cable - CAT 5e |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 1 m |
Colour | White |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS - up to 350 MHz |
